Battery Level
Discussion in 'Gome Flytouch' started by vaccdroid, Feb 21, 2011.
  1. vaccdroid
    vaccdroid Member
    On my flytouch I cant get the battery meter to read the battery correctly. It says 50% when fully charged ,then will jump to 100% after a half hour then after a bit will jump to maybe 72 % and count down from there. The battery fully charges and I get 2-3 hours out of a charge but the battery is not synced with the meter. I tried running the battery down to zero but when charged and I turned it on ti at 50% . I also tried 3rd party battery meters and they say the same thing as the built in battery meter. Any thoughts on a fix ??
    Thanks !
  2. probbiethe1
    Gilbert, Arizona
    if it counts down from 75 % when it gets there correctly and it gives to 2 to 3 hours a charge i wouldnt be complaining, but to answer your question have you tried a custom rom that might help sort things out
  3. vaccdroid
    vaccdroid Member
    Its probally closer to 2 hours to be honest ( i was being optomistic) and yes Im definetly not complaing as I have 3 Flytouchs and this one is the best of the three.(good , no lag wifi and responsive screen) and I can live with it but was just curious if there was a fix. You always want things to be perfect .As for custom roms I cant find one for mine . I posted the build of mine but I think there was not too many for it. (Below) And thank you.
    Memory - 256MB
    Model Number - Generic
    Firmware Version - 1.6
    Kernel Version - 2.6.29-00236-g4f8dbbb-dirty
    Build Number - WMT2.0.1_105
  4. probbiethe1
    Gilbert, Arizona
    i completely understand wanting things perfect but perfect is relative to the person using it. I dont know if you have check out this section yet Gome Tablets but it might have something for you
    • Like Like x 2
  5. Filipino013
    Filipino013 Member
    Philippines
    Android Epad Tablet Pc
    i charge mine everyday dam Why
  6. RomanticEvil
    RomanticEvil Member
    Tilburg, the Netherlands
    Gome FlyTouch / SmartQ7 / HTC X7500 / M006 / CVUK-PC06-2GEN / WMT2.1
    The problem you have seem to be related to a setenv given in the rescriptcmd, the value that's used now is not proper for your device, you can try other battery power setenv or another ROM in order to fix it, I have the same problem and am struggeling with it now, Good luck, wish me the same :)
    • Like Like x 2
ylevelon android tablet
