before i order please help me confirm
Discussion in 'Pandigital Novel' started by xghostyxjokerx, Dec 29, 2011.
  1. xghostyxjokerx
    xghostyxjokerx Member
    I wanted to find out if i can add the android market with this product without rooting the device???
    I wanted to ask if i can possibly root this device and with what roms are out there please links if any and video if any thanks alot...
  2. dansamy
    dansamy Member
    Alabama
    Droid X
    Pandigital makes a lot of ereaders based on Android. We need to know which one you're looking at buying.
    Sent from my DROIDX running MIUI
  3. xghostyxjokerx
    http://www.kohls.com/kohlsStore/cro...digital 7in Multimedia Tablet and eReader.jsp
    This Pandigital multimedia tablet and eReader fits your lifestyle. Its compact size and touch-screen control offer convenience. Plus, its diverse design lets you do anything from browsing the Internet to watching videos.
    • LCD touch-screen display with 600 x 800 resolution makes navigating easy.
    • WiFi and Hi-Speed USB 2.0 connectivity provide simple downloading.
    • Online accessibility lets you download more than 2 million books, magazines and newspapers.
    • Android operating system gives you access to special features and apps.
    • Headphone jack allows you to listen to music and audio books in private, while the built-in speaker lets you listen aloud.
    • Full virtual keyboard, volume up and down, and power on and off functions enhance your experience.
    • Internal memory has 2GB and the SDHC card slot expands memory up to 32GB.
    • Rechargeable lithium-ion battery provides lasting use.
    • Details:
      • Includes: stylus, AC adapter, USB cable & cradle/stand
      • 7.2"H x 5.2"W x 0.5"D
      • Screen: 7 inches
      • Manufacturer's 1-year limited warranty
      • Model no. R70E200
  4. dansamy
    dansamy Member
    Alabama
    Droid X
    That model runs android 1.5. It isn't upgradeable. I wouldn't buy it. See SlateDroid's Wiki about hacking the original two Pandigital Novel models. The "black" model, which comes in other colors than just black now, is notoriously a pain and not very hackable. The "white", which is also now available in other colors, is a pretty capable little model, ideal for hacking into a functional tablet and handing it off to the kiddos without fear that they'll ruin the $600 iPad or Xoom.
  5. xghostyxjokerx
    sorry i meant this tablet...Technical Specifications:[/LEFT]
    • 800MHz PAN8006 Cortex processor with 3D GPU
    • 256MB DRAM of system memory and 2GB on-board storage memory with microSD card slot for expansion
    • 7.0" ActiveTouch Resistive digital TFT LCD Color Touchscreen @800x480 resolution with virtual keyboard
    • Built-in 802.11b/g/n Wi-Fi
    Additional Features:
    • Front VGA camera
    • Mini-USB 2.0 port, micro-HDMI out
    • 2GB on-board storage memory, additional memory via microSD card slot up to 32GB
    • Orientation sensor, 2-axis accelerometer, ambient light sensor
    • Rechargeable lithium-ion 3400mAh battery
    • Weighs 12.8 oz; 7.9" x 0.5" x 4.75" dimensions
    Software and Applications:
    • Android 2.2 OS (Froyo)
    • Barnes & Noboles eStore & eBook App
    • Dictionary, Highlight, Notes, Bookmark & More
    • Android market (for applications download)
    • Media Formats: PDF, EPUB, MP3, WAV, AAC, MPEG-4, FLV, DOC, DOCX, TXT, XLS, XLSX, CSU, PPT, PPTX
    What's in the Box:
    • Tablet and AC adapter
    ]Walmart.com: Pandigital Star 7" Color Touchscreen Tablet PC & eBook Reader Featuring Android 2.2 (Froyo) Operating System, Barnes and Noble eStore, HDMI Out & Front Camera: Computers
  6. dansamy
    dansamy Member
    Alabama
    Droid X
    That one won't support flash or Netflix. It'd be a pass to me, but those might not be too important to you.
  7. xghostyxjokerx
    wont support flash even after rooting?
  8. xghostyxjokerx
    would this do? Pandigital Novel 7" Color Multimedia eReader (White) | P. C. Richard & Sonny guids on this is this the right place for this tablet?
  9. jbrink
    jbrink Member
    7" BPDN, 9" BPDN
    I'm not sure exactly how to do this. I'm pretty good with a computer and stuff but cant find anything straight forward on if this is possible and how to do it. Any help would be greatly appreciated.
  10. BobLap111
    BobLap111 Member
    New Jersey
    Pandigital Novel 7
    I have the Pandigital Novel 7 and its a pain to work with. Tech support from Pandigital is slow, took 3 weeks to answer a support question.
    This is my first Android anything and I got it to see how good/bad android is before buying a new phone. So far not liking the system too much but that may be Pandigital's fault.
    I performed the firmware upgrade to the latest version of Android that Pandigital supplied for this device and now most of the apps won't work, I get a message that the apps aren't loaded on the "phone". When I try to go to B&N to try to reload their app the device says the site isn't available try again later. I tried going to the Android store and can't get any apps to download because the "phone" isn't registered.
    It's probably me and my lack of Android experience but I never had trouble like this with other devices and software.
    UPDATE: Went thru the entire upgrade process a second time and this time the apps on the device are working. I've heard of updates that required two complete installs and I guess this is one of them.
