Big problem or video tv
Discussion in 'Viewsonic gTablet Technical' started by josep3, Sep 16, 2011.
  1. josep3
    josep3 Member
    I have a doubt.
    I have a Tablet and I want to watch TV or videos with the Wi-Fi Tablet but I get a message that I need "adobe flash" but I try to install it and says it is not compatible.
    As I can install??.
    In the Tablet I have Android 2.2
    THANK YOU
  2. beastman
    beastman Member
    Austin, TX
    gtab
    The "problem" is Adobe. I just had the problem again doing the update. The solution is to load it on your phone, and then use Astro to back it up. I once backed up, and copy the apk to your tablet and install.
