Bluetooth Keyboard Not Showing Up Cyanogenmod 10.2
Discussion in 'Samsung Galaxy Tab 2 7.0' started by mikee, Oct 9, 2013.
  1. mikee
    mikee Member
    Fairfield Iowa
    Samsung galaxy tab 2 7.0
    I just flashed cyanogenmod 10.2 on my tab 2 7.0 but now even with bluetooth on my keyboard doesn't even show up. Can anyone help me out here? I was sort of afraid of something like this happening. I mentioned that in my other thread about updates for the tab.
  2. SEMIJim
    SEMIJim Senior Member
    S.E. Michigan, U.S.A.
    Vizio VTAB1008, Samsung Galaxy Tab 2 10.1
    Sorry you're having the problem :( My Anker Bluetooth keyboard just paired-up and worked. I presume you went through the re-pairing procedure?
    Uhm... waitaminute... 10.2? 10.2 isn't a stable release. Why are you doing that?
    Jim
  3. SEMIJim
    FWIW: Just to be certain: I tried my Anker Ultra-slim Bluetooth keyboard again this morning. Paired-up and worked fine. But, again: That's with CM 10.1.3, not 10.2.
    Jim
  4. mikee
    mikee Member
    Fairfield Iowa
    ok i fixed the issue it was the keyboard itself went into some weird mode but now I got it back to normal and it works fine
    one thing I want to know though is I installed a thing called delete key as backspace so I could actually backspace using delete but I can't figure out how to enable it there doesnt seem to be a physical keyboard setting in language and input in cm. there wasn't in touchwiz either though.
  5. SEMIJim
    Glad you got it working. Can't help you with the delete key thing. Have no clue. My keyboard has a backspace key.
    Jim
acer iconia tablet bluetooth keyboard not showing
bluetooth keyboard cyanogenmod
cyanogenmod samsung bluetooth keyboard
cynogenmode bluetooth keyboard
galaxy tab 3 cyanogenmod bluetooth keyboard problem
paired bluetooth keyboard not showing in langauge and set up galaxy tab 3
samsung bluetooth keyboard not showing up physical keyboard
