Can't start my brandless tablet. HELP
xFox
Hey guys, I have a brandless tablet runing android, can't tell you anything about it cause I had it by someone.... I just wanted to know if theres any way to open it, i joined 2 pictures! Note that the tablet is been not running for 3-4 months! Thanks in advance guys!
leeshor
6,330
1,037
Welcome to the forum
I suggest you use the charging cable to plug it into a running PC for 5 hours then long press the power button.
xFox
Thanks! The only probleme is that i don't have the original wire, its broke. I use a 5volt DC wire that came with a bluetooth, will it works ?!
leeshor
6,330
1,037
Hard to say. In theory the cable should/would work but the charger is a concern.
