caps lock
J
jimbo7630
Guest
Ref. those two suggestions you'll know the caps have locked when they remain as Caps on the KB if, of course, they return to lower case - they aint locked!
hardlec
12
Thanks.
With 20+ years on a PC, learning the differences on a tablet has taken some time. I still havent figured out cut and paste...
photoweborama
132
17
here is another tip, some soft keyboard have the numbers low lighted on the top row of the qwerty keyboard. If you long press the key a dialog box pops up and it scrolls you through the options, be it letter, number or I think symbols.. Not sure on the symbols... I dropped my tablet in the sink, so I can't test it...
J
jimbo7630
Guest
Have you done the Rice Cure yet? lol.
konachris
7
On mine I hit the CAPS button twice and a green light appears when its locked.
Sent from my Full Android on S5PV210 using Android Tablet Forum
