car charger
Frederuco
Super Moderator
1,980
503
It depends. Check the charging specs on the charger that came with it. Many tablets have custom wall warts that use more than 5 VDC to charge faster. If that is the case, standard USB port chargers may not work well.
If it is, most USB chargers will work. Best case scenario, get an iPad USB car charger (usb style) that outputs 5 VDC and 2 Amps for best results (so long as you can charge with 5 VDC).
