Ie there anything that is a case and keyboard for xoom ? So it connects the two and makes it sort of resemble a laptop ? (Something like the asus transformer) Sent from my ADR6300 using Tapatalk
What size is yr tab? I've just got a 10'1 in FTII Var 2 with a fab keyboard/case USB plug. Tab fits inside & then seals like a small folder measuring 11" x 7" with tab.
This works well with 10" I pad, Fake leather but built well, 25.99 at ***************,just do not buy any electronics there, the build quality is the worst on the market.
I was thinking for xoom 10.1 inch So with that one I just plug in the usb? Sent from my ADR6300 using Tapatalk
Right your Xoom should fit just compare Original I pad measurement to your xoom. The Xoom will charge the battery in the keyboard.
Dumb question: I bought the case from US supplier so I had in 2 days, but how do I hook USB plug into xoom since it is not the mini USB plug? Seems useless to me now but the quality of the case is great Sent from my sdk using Android Tablet Forum App
May 19th 2011 Just purchased this today from *************** Should have in the next couple of days and will let you know how I make out.
Keyboard & Case For Motorola Xoom Ok just got my case from *************** and it took almost2 week to get deliver from Hong Kong. There was a problem with the order so Ihad to e-mail them at nowsupplier@gmail.comand they were very responsive. Over all the Case & Keyboard look good, but I still needto find a USB Female to Mini USB connector. I went to Best Buy but they did not have what I needed. At this point Iam happy with the product and would recommend it. Once I have a chance to play with the Keyboard I will sendout anther update….Total investment so far $ 47.53 One more thing…there website said that it would ship UPS butit was DHL
