Charge COBY Kyros Via USB Cable Possible?
Discussion in 'Coby Tablet Accessories' started by Stinky Emperor, Feb 4, 2011.
  1. Stinky Emperor
    Stinky Emperor Member
    NULL
    Hey everyone! :)
    I would love to get the COBY Kyros 7015 and I am really considering it...
    I apologize in advance if this question is common knowledge or has been answered before.
    I did try using the search bar / function but was unsuccessful.
    I found this but I think it is not what I am looking for since it is a modification:
    http://www.androidtablets.net/forum...t/6206-hardware-usb-cable-charge-mid7015.html
    Basically can anyone tell me if it is possible to charge a COBY Kyros MID 7015 via an USB cable to computer / PC?
    The reason why I am asking is because I live in South Africa and our plugs and power voltage are different to the USA.
    We run on 220 volts here in SA where as the USA runs on 110 volts.
    I am going to import my COBY Kyros via take2... they are our amazon import service and would just like to know if it will charge off a pc USB or not?
    http://more.take2.co.za/usa?qsearch=coby kyros
    Can I use a universal charger that has a built in USB charger to charge through the COBY 7015's female USB port?
    If anyone has any other recommendations I would be very happy / grateful to hear them!
    Thanx in advance for any help! :D
    Regards
    Stinky Emperor
  2. Ridgeland
    Ridgeland Member
    Ridgeland, WI, USA
    Coby MID7015-4G
    You can not charge your Koby from USB with the cables that are provided with the unit. Those cables are for data transfer only.
    PC specs for USB 2.0 are 0.5A output. The Koby needs 2A.
    But I don't think you need anything more and a plug adapter - flat US pins to local pin spec.
    Here is a photo of the bottom of the charger that came with my MID7015
  3. Stinky Emperor
    NULL
    Hey RidgeLand! :)
    Thank you for the nice response!
    I understand now and thanx
    Keep well
    Regards
    Stinky Emperor
  4. emmerick
    emmerick Member
    Brazil
  5. Ridgeland
    Ridgeland Member
    Ridgeland, WI, USA
    Coby MID7015-4G
  6. emmerick
    emmerick Member
    Brazil
charge coby kyros through usb
coby charger
coby kyros charger
coby kyros tablet charger
coby kyros usb charging
how to charge a coby kyros without charger
how to charge a kyros tablet
how to charge coby kyros without charger
how to charge coby tablet with usb
what kind of charger does a coby kyros use
