Charging Issues :(
Discussion in 'Acer Iconia A100' started by Aleaha1227, Jul 5, 2012.
  1. Aleaha1227
    Aleaha1227 Member
    Shamokin
    Android a100
    Purchased this tablet at the end of March for my daughters birthday havent had a problem with it till this morning, it wont respond to the charger. I changed outlets, i wiggled it, unplugged and replugged numerous times and wiggled some more with no results. The screen continues to show low battery and tells you to plug in the charger. I had this same exact problem with my Driod Bionic cell 2wks ago (i had it for less then 30days). Im not all that handy on the computer and couldnt find any information online with this being a problem for other ppl with this tablet/phone. Does anyone know anything about this "charging issue" my droids seem to be having? Any suggestions how to fix it? They were both purchased at Best Buy so if I cant find a solution im taking it back and throwing a hissy till it gets fixed! :mad:
  2. Astrix
    Astrix Super Moderator Staff Member
    Singapore
    Public Phone
    Welcome to the forum
    Seem like charger not doing well.
    - Maybe faulty charger?; or
    - Your country/house voltage supply, is it same spec with your charger requirement?
  3. probbiethe1
    Gilbert, Arizona
    I would suggest taking them back and getting replacements. There is no way your devices should be having charging issues this early. The only feasible thing that I could see causing this issue this early is if the cord or the adapter that plug into the wall is bad.
    • Like Like x 2
  4. Aleaha1227
    Aleaha1227 Member
    Shamokin
    Android a100
    Probbiethe1,
    Thank you. That is what I am most likely going to be doing this weekend. I dont know maybe it is the electrical output, thing is we use different outlets all over the house and everywhere we go those chargers and devices go with us. :(
    My daughter is lost without her tablet so I will be returning it ASAP. Thank you for your suggestions. :)
  5. Nanook626
    Nanook626 Member
    Florida
    ACER Iconia A100 tablet
    I am having the same issue,only my tab is 9 months old. I am in the process of emailing back and forth with their customer service, which is located somewhere in India! I have thus far, not been impressed. I have been given wrong information and told my tablet wasn'tunder warranty.
    Did u take your tab back to the store?
  6. jimabbey
    jimabbey Member
    Ontario Canada
    Acer A100
    My A100 will not take a charge. The tablet will run but will not charge the battery. Storage indicates less than 2 min of life in battery. I have replugged the charger in several times in different outlets. The icon on the screen indicates that there is AC power but the unit is still not charging. The tablet is about 9 months old. What can I do?
  7. Douvie
    Douvie Senior Member
    Kyneton, Australia
    Just a little note:
    Never let your tablet battery go below 15%. I've kept mine fully charged most of the time. And only once got down to 30% - and never had a problem yet.
    Also make sure you use an OEM charger - the others will not work.
  8. turbocoop
    turbocoop Member
    United States
    A100, A200
    These have a lot of problems with the charger itself, I would try checking that first. Maybe take it to best buy and see if they will let you plug it into a charger???
  9. Douvie
    Kyneton, Australia
    A lot of these unit seem to have been sold without the original OEM plug pack - some cheaper plug pack supplied instead. The OEM plug pack has a very short cable - very annoyingly short.
    The plug on the cable is not a readily avaiable type and is a ACER type plug. This is where the problems start.
acer tablet charging problem
acer tablet charging problems
android tablet charger not working
Android Tablet Charging Problems
charging problems with android tablet
how to charge acer tablet without charger
tablet charging issues
tablets will run but not charge
xo tablet not charging
xo tablet wont turn on
