Class 4 or Class 6 micro SD Card.. does it make a difference for a tablet pc?
Discussion in 'Android Tablet Q&A' started by anoopathiyarath, Apr 23, 2012.
  1. anoopathiyarath
    anoopathiyarath Member
    India
    MicroMax Funbook
    Class 4 or Class 6 does it make a difference for a tablet pc?
    I bought a new tablet PC and am planning to buy a new 32 GB Micro SD card for it. I looked two cards of same memory. One is a class 4 card and other a class 6 card. with a price difference of 10 dollars. Is going for a class 6 card really needed?
    Few specs of this tablet PC - 0.3 front cam, no primary cam, plays HD videos, 4 GB internal memory, 512 MB Ram & 1.2 GHZ processor. Android 4.0 ICS,
    let me know if purchasing a class 6 card really makes any difference in tablet performance.
    Thank you in advance
    Anoop.
  2. Spider
    Chicago, IL
    I've found that a class 4 card is fast enough for anything I do on my tablet including watching videos and movies. I also use class 4 for Titanium backups and for flashing and backing up ROMs.
    • Like Like x 2
  3. Frederuco
    Frederuco Super Moderator Staff Member
    /EARTH/USA/NC/
    ASUS TF101
    [​IMG]
    The class of the card pertains more to write speeds than read speeds. Using a C10 vs a C2, the biggest speed difference will be noticed copying files to the card not during playback.
    Also, some users have tested different cards and found that come C4 cards are faster than other C10's. This is because the Class is the minimum speeds, but some cards can be faster.
class 4 vs class 6 microsd card
class 6 sd card vs class 4
is class 4 microsd fast enough
is class 4 microsd fast enough for android
is class 6 sd card fast enough
micro sd card class 4 vs class 6 vs class 10
microsd class 4 vs class 6
sd card class 4 vs 6
what class sd card for pc tab
which class is best in class 4 or class 6
