CM7 Nook Color Will Not Load
Discussion in 'Nook' started by smilnjack27, Jan 11, 2012.
  1. smilnjack27
    smilnjack27 Member
    Nook Color auto rooted
    Ok I have tried to root my nook to CM7 at least 5 times so far and nothing works. My NC software version is 1.2 I had tried to root it earlier and it just froze so I finally went this route:
    1. Download all of the above files and put them in a convenient location.
    2. Create an bootable Clockwork Recovery SD card.
    3. With the same SD card you just created. Copy the following files to the root directory of the SD card update-cm-7.1.0-encore-signed.zip and gapps-gb-20110828-signed.zip
    4. Insert the SD card into your turned off Nook Color. Turn on the Nook Color.
    6. Navigate to install from SD card and install update-cm-7.1.0-encore-signed.zip. Then install. Once gapps-gb-20110828-signed.zip if you have not already from another Cyanogenmod version.
    7. Go back to the home screen using the power button to mounts and storage.
    8. Format Cache. Then navigate back one screen to advanced>wipe dalvik cache.
    And each time it loads and I see the little android with the hand that goes to him to click on him, I click and it say's the process android.process.media has stopped unexpectedly please try again
    Please let me know what I should do to fix this and get my NC to work
  2. williesmith
    williesmith Member
    NJ
    NC
    Did you wipe data with clock work mod before loading cm7?
  3. Sue7M3
    Sue7M3 Moderator Staff Member
    The Big Apple
    Nook Color (Rooted)
    Please go to the technical section and read the stickies and posts there. Your questions have been asked and answered many times and the info in that section should help.
  4. Sue7M3
    The Big Apple
    Nook Color (Rooted)
    And please stop creating a new thread everytime you have a new question about the same issue. Keeping them all together in one thread makes it easier for folks to assist and keeps the board from getting cluttered. Thanks and enjoy your Nook!
nook color not loading
process has stopped cm7 nook color
