Coby Kyros MID1042 Problem
Discussion in 'Coby Generation 3' started by mvancil, Dec 26, 2012.
  1. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    I have a Coby Kyros MID1042 that has a corrupted Superuser.apk
    I have attempted to reset to factory and to re-root using ADB. This has failed, because the file already exists and all of the rooting tools (and manual attempts) to copy the file will not overwrite the existing. I am able to boot the tablet as normal and I can access the system recovery, but I cannot use any of the custom roms because they fail signature verification. I cannot upgrade the rom manager because I can't get root.
    So....my question is this....does anyone have the stock rom for the MID1042 that will pass signature verification? Or any other rom for that matter that will pass?
  2. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    Use adb to root your device, then use adb to replace Superuser.apk.
  3. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    As stated before....that didn't work.
  4. vampirefo.
    Huntington WV
    no way it can't work, you are simply do it wrong, post exact commands you are using.
  5. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    It's absolutely does not work. I do know what I'm doing. The problem is that it will not overwrite any files that already exist, and I cannot erase them without root access. Here's an example of the commands issued...
    adb.exe push data /data/local/tmp/
    adb.exe shell chmod 0777 /data/local/tmp/mempodroid
    adb.exe shell /data/local/tmp/mempodroid 0xd7cc 0xad27 sh /data/local/tmp/root.sh
  6. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    I also attempted to use the -f flag to force the overwrite, but that doesn't work.
  7. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    Oh....and the root script...
    busybox mount -o remount,rw /system
    cd /data/local/tmp
    busybox cp su /system/xbin/su
    busybox cp reboot-recovery /system/bin/reboot-recovery
    chmod 755 /system/bin/reboot-recovery
    chown 0:0 /system/xbin/su
    chmod 6755 /system/xbin/su
    busybox ln -sf /system/xbin/su /system/bin/su
    busybox cp Superuser.apk /system/app/Superuser.apk
    chown 0:0 /system/app/Superuser.apk
    chmod 0644 /system/app/Superuser.apk
  8. vampirefo.
    Huntington WV
    adb shell
    su
    rm -r /system/app/Superuser.apk
  9. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    adb server is out of date. killing...
    * daemon started successfully *
    shell@android:/ $ su
    su
    Segmentation fault
    139|shell@android:/ $ mount -o remount,rw /system
    rm -r /system/app/Superuser.apkmount -o remount,rw /system
    mount: Operation not permitted
    255|shell@android:/ $
  10. vampirefo.
    Huntington WV
    ok so you aren't rooted, you need root to remove /system files.
  11. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    It was rooted...the files are now corrupted...hence the need for original post.
    Unless you know a way to force an overwrite while rooting?
  12. vampirefo.
    Huntington WV
    your su binary appears to be corrupt, once you become root $ changes to #
  13. vampirefo.
    Huntington WV
    rooting has nothing to so with Superuser.apk, you must be root before you can even push the Superuser.apk.
  14. mvancil
    mvancil Member
    Tennessee
    SYNET7LP
    We still have yet to hit on anything I didn't already know.
  15. vampirefo.
    Huntington WV
    adb push data /data/local/tmp/
    adb shell
    su
    $ should now change to #
coby kyros android mid 1042 factory reset
coby kyros mid1042 hard reset
coby kyros mid1042 reset
coby kyros mid1042 tablet hard reset
coby kyros mid1042 troubleshoot
coby kyros model mid 1042 hardreset
coby mid1042 hard reset
coby signature verification failed
factory password on coby kyros mid 1042
hard reset tablet coby kyros mid1042
how do you do a hard reset coby kyros mid1042
how to factory reset a kyros mid1042
how to format koby kyros mid 1042
how to hard reset coby kyros mid1042
kyros coby mid1042 need tech help will not reset
mid 1042 hard
mid1042 reset
rom tablet coby mid1042
