Coby Kyros MID70X5 Eclair System Improvements
Discussion in 'Telechips TCC8902 Development' started by xaueious, Jan 20, 2011.
  1. xaueious
    Canada
  2. l_n
    l_n Senior Member
    TN, USA
    Mid7015
    I downloaded the lib, but haven't had time to push it on the tablet yet. I'll let you know how it works out.
  3. l_n
    l_n Senior Member
    TN, USA
    Mid7015
    I've been using your libwebcore, and it seems to do well. No crashes or anything else unexpected.
    Sent from my MID7015 using Tapatalk
  4. xaueious
    Canada
    Did you notice the animated GIF files, or was that enabled in the original firmware?
    Any comments about speed? It might not be much faster, but does it feel any slower?
  5. l_n
    l_n Senior Member
    TN, USA
    Mid7015
    It's not slower and I haven't noticed animated gifs (but I wasn't looking). It seems pretty quick. I did notice the login graphic on touch.facebook.com was just a blue bar, but that could have been facebook's fault.
  6. xaueious
    Canada
    If it looks like the following, it's normal (on Miren browser with the Acer Liquid E, Android 2.2 with v8 webkit)
    [​IMG]
  7. l_n
    l_n Senior Member
    TN, USA
    Mid7015
    Yep, that's it.
  8. xaueious
    Canada
    I guess this can be repacked into a Coby addons update.zip sometime, along with whatever else that might be useful for it...
  9. regnaD kciN
    regnaD kciN Member
    It would be fantastic if you got get Google Calendar sync running as well...
  10. xaueious
    Canada
    Google contacts sync actually works on my X5A. What does it not work on right now?
    You will need to push Contacts, Phone, and GoogleContactsProviders. It will batterydrain unless you enable Airplane mode.
