COBY KYROS MID9740 BOOTLOOP AND NOT DETECTED BY PC
Discussion in 'Coby Generation 3' started by Jeyemjeyes, Dec 29, 2014.
  1. Jeyemjeyes
    Jeyemjeyes Junior Member
    My Coby Kyros MID9740 was in the boot loop state and I try the different key combinations to enter recovery mode but there's nothing happen, also, I connect my tablet to my computer but my computer can't detect it :( my tablet is rooted .
    Please HELP me , what can I do ! :(
  2. kevinthefixer
    kevinthefixer Member Developer
    Arizona
    Coby Kyros MID-9742-8
    First make sure your tablet is off. Not sleeping, not in APX, but off. Holding the power button down for 10-15 seconds should force it off whatever mode it's in.
    Which key combos did you use? the 9740 is not easy to get into recovery, the timing is critical. Make sure it's fully charged, then unplug the charger; for some reason nearly all tablets are reluctant to boot into recovery while charging. Press volume-down and power simultaneously for 1 second. If you see the Coby logo you waited too long, but it may go ahead and boot into recovery anyway, mine does sometimes. If not press and hold the same 2 keys until you do see the Coby logo; release power until you see the recovery, then release vol-. If you see the Android word centered in the screen you missed and will have to try again.
    You say your tablet is rooted, do you have CWM recovery? That would make things much simpler...
  3. Jeyemjeyes
    I don't have a CWM recovery sir. I tried many different key combos like holding the power and volume - button; power and volume + button; power, volume - and back key; power, volume + and back key, but there's nothing happen.
  4. kevinthefixer
    Arizona
    All I can say is keep trying. If you cannot get into recovery, and cannot aquire adb access, you may have to look for another tablet.
  5. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    Turn off tablet, now press and release volume up + power, now hold volume up + power down til you see Coby boot screen now release power keep holding volume up.
    sent from my kingSing T1 via taptalk
android bootloop tidak detect di pc
boot looping tablet detect computer
coby 1017
coby 1017 tab bootloop
coby kyros mid9740 stuck on android logo
coby kyros not booting
coby mid 9740 charger
coby mid9740 bootloop
coby mid9740 stuck on android screen
what to do colby tablet stuck on andriod mid9740 model
