COBY MID7010 Problem
lolerbober
Hello,
I have a COBY KYROS MID7010-4G and I have a problem with the ...
Android market app installed and now it starts.
coby on boot logo shows first, second, the Linux penguin, third android_ text and image android finally show endlessly and never gets off the OS.
I hope you can help me fix it.
try to start it by pressing the home button and power but shows me a text:
Unexpected update mode!
Please reboot your device.
when I connect to my pc reads as two "COBY MID7010 USB DEVICE STORAGE"
They could tell me how do I reset factory?
or to put it back the firmware?
I read this post on the forum ""Coby Kyros MID7010 (MID 7010) FACTORY RESET, Rooting, Android Market"" and not help me.... :(
shoesmagnate
Hi there,
At first I have the same problem as you were experiencing, since i have wifi problem wid my coby kyros 7010wc tablet, I opted to connect via Usb thru my pc.
I downloaded the google play store version 4.5.10 thru 4shared and save it in my external sd memory then after which i installed it and it still runs smoothly
Hope this helps..
