Coby MID8065 Recovery System
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
I have a feeling @tpaine that your system dump might also be corrupt. since you have root, cant you just mount the system as RW and then just zip up the system folder using a file manager?
This is possible, we need a dump from a tablet that hasn't used the 7065 recovery.
Sent from my SPH-D710 using Android Tablet
bludot
44
$log.JPGView attachment 11826So... I got logs :D Since I am using the 7065 recovery I decided to just use the twrp recovery. cant ruin my tablet more can I? anyways, I'm lazy so i posted pics
you dont know how long it took just to rotate it :/ stupid computer he he
tpaine
525
130
Will give this a try later today. I did make a cwm nandroid backup if you want to try it. Remember, this may be damaged. Haven't tried restoring this myself, ...not yet ready.
8065_CWM_Backup
Your bootloader arguments in recovery look like mine, pics at vamp's thread.
bludot
44
restoring via fake recovery (after updating via stock recovery) and there is an error while restoring system :/
woah! theres some progress: got a blank screen. so it booted further to some place.
running attempt 2:
differences: remove the empty system.tar and cache.tar and renamed system.tar.a to system.tar and did the same with cache.tar.a
Still error restoring system. wonder why :(
bludot
44
HOT DIGGITY DOG :D
got my tablet back :D
I used the system dump from before that @tpaine posted. the system from cwm was corrupt
I might have root now too :p
UPDATE: YUP got root :p thanks for all your help. maybe We can have people root via this backup? obbosed to the method of adb. It will wipe the tablet though.
bludot
44
if you backup the recovery via /dev/mtd/mtd3 i think thats recovery then you get the real recovery.
tpaine
525
130
HOT DIGGITY DOG :D
Great news! Glad to hear it. Glad you exchanged your 7065 for a real 8065 !
Vampirefo uses a flashable zip for root, but other methods could work. My system backup has /bin/su so thats root I guess. Should have different busybox, too... Maybe thats part of the backup problem...?
jeffreyd015
Sep 15, 2014
Hi do you have the system you use to make your tablet work? can i use it? i badly need it to make my tablet work again.
vin2224
Jun 18, 2015
HOT DIGGITY DOG :D
good day sir.
I really need your help.
i know this thread is very old but i hope that you can still teach me the step by step solution for this problem.
or you can just tell me the programs needed in order to fix this problem.
Thank You so Much in Advance!
