OutaDaDark
- Mar 18, 2011
- 19
- 1
I have an Iomega 1 Terrabyte hard drive and several 80Gb, 160Gb and 320Gb drives that all work using USB Mount All.
They are variously formatted to FAT32 and NTFS.
..... and OP, try formatting your USB stick on the system your pal used to format his. Be careful with the HP Formatter, there are several different versions. There is a version onthe site of a company called WITSTECH. I have never had a problem with anything formatted with this program.
Good luck
G
Good luck
G
