Connecting to PC with USB
Discussion in 'Vizio Tablets' started by jhig1961, Mar 13, 2012.
  1. jhig1961
    jhig1961 Member
    Anyone else having problem connecting to PC with USB cable after honeycomb update? I plug it in ang get nothing.
  2. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    Same here. When I connect the VTAB1008 to USB, I hear the standard Windows connect sound (and the disconnect sound when unplugging the USB cable) but I never see the connected drive. FWIW, I'm running ADW launcher v 1.3.3.1. Not really a show stopper, since I can connect over WiFi using ES File Explorer) but would like to get this connection working again.
  3. J515OP
    Northern CA
  4. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    Don't have a problem accessing the external SD card from the VTAB8000. It's the USB connection with a 64-bit Windows 7 Ultimate PC that doesn't work.
  5. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    VTAB8000 USB connection works just fine on a Compaq Notebook PC running 64-bit Windows 7 Premium with an AMD CPU, but nogo on the desktop running 64-bit Windows 7 Ultimate with an Intel i7-2600K.
  6. mui
    mui Member
    usa
    MT4G,Vtab1008
    I'm not able to connect with linux either
  7. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    Just tried it successfully on another notebook: HP DV2000 64-bit Windows 7 Ultimate with an AMD CPU. No more systems to try...mus be something with the desktop PC.
  8. J515OP
    Northern CA
    Hmm, maybe you can try clearing the device from the device manager on the pc, then plug it back in and see if it is recognized.
  9. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    VTAB1008 device appears in Devices and Printers on Desktop Windows7 Ultimate system, but with no drives.
    "There is a problem with the driver for the USB Mass Storage Device"...reinstalled device driver
    VTAB1008 Properties...Unknown Device...Device Status:The drivers for this device are not installed. (Code 28)
    VIZIO downloads site (http://www.vizio.com/vtab1008.html#support) has "Windows USB Drivers for Android: Windows USB Drivers for Android"... file "1139VTAB1008USB.zip" contains folders "amd64" and "i386" but no installers.
  10. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    Got the Windows USB Drivers for Android installed. Device is now recognized as "Android Composite ADB Interface" but still no drives.
  11. BailableOdin
    BailableOdin Member
    Indiana
    NookColor CM7/VTAB1008
    How did you install the drivers?
  12. james23p
    james23p Member
    Memphis
    Samsung Galaxy Tab 2 7.0
    On my HP Omni 220 running Windows 7 Home Premium 64 bit I didn't have to do anything the Vtab automatically downloaded the drivers the first time I plugged it in after I updated to honeycomb. To see my files I went to (my computer). Once there I see Vtab 1008 Media Player when I click the Vtab my SD Card shows up with all its content and how much room I have left. I then can move files back and forth from the Vtab and my computer with no problems. I just added another 30 or so photos with no problems what so ever after the Honey Comb update.
    Here's a link to Vizio's website, once there click support and there is a link to Android drivers for Windows.
    http://www.vizio.com/accessories/vtab1008.html
    Sorry I see the link was already provided earlier in the thread.
    Jim
  13. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
  14. yottabyte
    yottabyte Member
    Reno NV
    VIZIO VTAB1008
    If the VIZIO-provided USB drivers were already installed, uninstall them and be sure to also remove the driver files! This will generate a new entry in Device Manager...Other Device...VTAB1008 with a yellow exclamation point!
    Right-click VTAB1008 and select "Update Driver Software"...
    Click "Browse my computer for driver software"
    Click “Let me pick from a list of device drivers on my computer...”
    Scroll down in the Manufacturer window (left side) until you get to Portable Devices, highlight it and click next.
    Click "Standard MTP Device"
    Click "MTP USB Device" in the Model window (right side) and click on NEXT
    Click YES to the Update Driver Warning
    VTAB1008 should now be listed under Portable Devices
    • Like Like x 12
  15. stevepike
    stevepike Member
    georgia
    vizio tablet
    Thanks for resovling the issue of not being able to access the tablet from my PC after the honeycomb update.
86vebc driver download
86vebc usb driver
86vebc tablet driver
android tablet connect to pc software download
android tablet to pc connection software download
neutab i7 tablet android adb usb driver
polaris tablet pc usb drivers
vizio 1008 wont connect to pc
x tab 86vebc usb driver
