I would suggest that as a first step you power the router off for 30 seconds then back on again.. Then, if you could, tell us what is happening when you try to connect.
hi, back of hols had great time. i took tablet with me and had no prob connecting to hotel free wifi. at home pad finds router after puting in pass word mand clicing connect the pad say saved and connecting but goes no further. i have tried reseting router and pad back to factory dfault with no change. i took the routers security settings of and tried with same result. ihave set all router channels as all and individualy with same result.tonight it picked up BTFON wifi and loged on ok did not use it as u have to pay. so the problem seems to be at my router but i`m baffled what to try next. hope you can help.
