Hi all,
I'd like to ask for some community assistance, to gather A700 temperature data. To those willing to help, please do the following:
1. Install SetCPU from XDA & System Tuner from Google Play:
SetCPU:
SetCPU for Root Users [2.2.4] Undervolting and more 07/07/2011 - xda-developers
System Tuner:
https://play.google.com/store/apps/details?id=ccc71.pmw
2. Open up System Tuner, go to CPU, and write down what the CPU Temp is. Try doing this while nothing else is running. This will be your "idle baseline."
3. Switch over to SetCPU. Ignore all of the prompts if you are not-rooted. Go to Info->Stress Test. Run the Stress Test. It will continue to run until you stop it.
4. Wait about 2 minutes, then switch back to System Tuner. The act of switching apps will stop the Stress Test. Record the CPU temperature again.
Repeat if you wish.
Please post back with the following information:
Rooted = Yes or no
Baseline Temperature = ?
Post-Test Temperature = ?
Thanks all!!
SetCPU:
System Tuner:
Repeat if you wish.
Rooted = Yes or no
Thanks all!!
