Creative ZiiO 7" and Nokia LD-W3 GPS Problems
Discussion in 'Creative Tablets' started by liberalul, Feb 21, 2011.
  1. liberalul
    liberalul Member
    Hi, I have a tablet Creative ZiiO 7" Android 2.1 and a Nokia LD-W3 GPS that I connected via Bluetooth, but does not work, it says "Paired But Not Connected" I don't have an option to connect them .... .
    Any ideas to solve the problem ?
  2. mechir
    mechir Member
    Malaysia
    Creative ZiiO 7
    Based on the Nokia GPS module's spec as on this page, i believe its output is NMEA.
    i use this BlueGPS app in my ziio to received nmea signal from my wm6 phone (using gpsgate to transmit bluetooth gps signal).
    i believe in android market got similar app: Bluetooth GPS
    choose your phone ID/name in "choose bluetooth gps" option. this combination of app and setup works for me so far. tested in Google Map.
  3. liberalul
    liberalul Member
    Thanks, it works with BlueGPS !
    Thanks Again !
  4. mechir
    mechir Member
    Malaysia
    Creative ZiiO 7
    good that it works. :)
  5. j00ls
    j00ls Member
    It sounded so good and looked very promising :(
    I am using a ziio 7" and a Samsung GT-B2710
    The Samsung is "Paired But Not Connected" as described and selected as a source in BlueGPS
    however the software I am using cannot find a GPS signal ("GPS Status" and "iGO")
    any idea what could be the problem?
greative ziio gps
