Disgo 6000 v2.2 Boot Problem FIXED
Discussion in 'Sylvania Tablets' started by danboy, Feb 20, 2012.
  1. danboy
    danboy Member
    Got a disgo 6000 running 2.2 out of the box, that gets stuck on the Disgo screen.
    Tried resetting (3 different methods) and it doesn't, it just goes to the Disgo screen.
    method 1
    Press on and hold the touchscreen, then press the power and menu buttons at the same time.
    method 2
    with device off
    push power turn on as normal
    Once you see the infotmic logo press and hold power and menu
    When you see white text On the screen release power and menu
    method 3
    Try holding the Reset button on the back for a full 10 seconds. See if it will boot. If not try doing the "3 finger salute" (holding the power button AND the menu button AND touch the screen) to boot it... if it will go through the attempt to "recover" your tab it will still work if you flash it.
    What else can I do?
  2. danboy
    danboy Member
    I have created a bootable SDCard for this, and the tablet does see it.
    Now all I need is the correct zSYS.img file.
    Anyone?
  3. danboy
    danboy Member
    Managed to revive it.
    Used disgo_12.2.0.5.1.4.ius
    Used IUW and an sd card to flash it.
    Installed and working.
    Now showing kernel version 2.6.32.9
    I don't know version prior to this
  4. ssme
    ssme Member
    UK
    DISGO 6000 2.2 (out of the box)
    Brilliant advice... thanks mate!
disgo tablet 6000 factory reset
disgo tablet not booting
