Dish remote AND Slingplayer apps don't work!
Discussion in 'Telechips TCC8902 Tablets' started by wmwinn, Jan 8, 2011.
  1. wmwinn
    wmwinn Member
    NULL
    These two apps install just fine, but immediately close after opening.
    Anybody else having this problem?
    Sent from my M701 using the AndroidTablets app
  2. wmwinn
    wmwinn Member
    NULL
    I confused why these Android apps don't work on my tablet. Any thoughts?
  3. bnewk1
    bnewk1 Member
    Philadelphia
    EVO 4G, Nook Color& Touch Pro2
    Dish remote and slingplayer is a memory hungry app. If you have Advanced Task Killer use it to close the other running apps then try it. I assume you have a sling player adapter and set it up to work with your box. if you have a 722 box.
