Dreambook W7 GPS problems !!!!!
Discussion in 'Freescale Based' started by jxp, Jun 19, 2011.
  1. jxp
    jxp Member
    Just picked up a new Dreambook and noticed there seems to be a problem with the GPS.
    Is anyone using the GPS function? I installed Copilot and also GPS Test and discovered the speed field is double the actual speed. Copilot goes mental but GPS Test ( and other apps) actually shows the speed is exactly 2x the real speed. Even tried it next to my old Tomtom and it's exactly the same.
    Tried both MPH and KMH and both show 2x the actual speed.
    My Dreambook is running B02V03-20110509(HD105).
    Any ideas anyone. It's a shame Synrgic doesn't run a support forum.
    Cheers
  2. Dreambook
    Dreambook Member
    Sweden
    Dreambook W7
    Mine does the same 2 * Speed
    V24 (104)
  3. sarabvi
    sarabvi Member
    My GPS is not working at all... Couldn't find my location..... Tried Google Maps and GPS test as well... anybody knows how to solve this problem?
    I have tried v20, v25 and now running andrioid 2.3.3 beta version.
  4. Werk_AG
    Werk_AG Member
    Lisbon - Portugal
    Dreambook W7
    Even with 2.3 beta version this annoying GPS bug still remains. I hope Synrgic fix it, in time to the upcoming official 2.3 release.
  5. sarabvi
    sarabvi Member
    Any help would really be appriciated, Can anyone tell how to fix gps problem. I mean its not getting any sigs, not fixing to ny satellite, so not showing my location at all. Iv tried indoor n outdoor wid loads of different gps apps.Pls help me wid dis thing, its really driving me crazy.
  6. Werk_AG
    Werk_AG Member
    Lisbon - Portugal
    Dreambook W7
    Your GPS never worked, or just after the upgrade?
    What happens after you turn GPS on in settings?
  7. sarabvi
    sarabvi Member
    It never worked. Recieved it about 2 weeks ago and gps wasn't working, Upgraded with v20 and then v25 but no joy.
    Well I ticked the box in Settings > Location & Security Settings > Use GPS Satellites > yes
    In google maps it can't find my current location. infact its not giving me any location at all.
    In GPS Test. GPS on green light. But no Long or Lat 0:0:0
    I have recently upgraded to Android 2.3.3 via MFG Tools but its still showing the same thing...
  8. Werk_AG
    Werk_AG Member
    Lisbon - Portugal
    Dreambook W7
    You may have a hardware problem with the GPS receiver. Have you reported the problem to seller?
  9. sarabvi
    sarabvi Member
    yes i did and he goes install the v20 and everything will be fixed.
    So you think its a hardware problem then? :(
  10. Werk_AG
    Werk_AG Member
    Lisbon - Portugal
    Dreambook W7
    I thought that you had a malfunction with your GPS hardware, but if it works with v20, is not a hardware malfunction.
