Easy Battery Saver
jdsteckling
8
I made the huge mistake of installing "Easy Battery Saver" and it has ruined my 4G connection. I can still connect WIFI but not at all any other way. Has anyone else had this problem? :mad:
JD
Spider
15,785
1,813
Delete it and see if the problem goes away. If it does, you're done.
bungholio
7
Agreed. Or just go and put it in normal mode and it free up all connections and whatever other stronghold it has on your device.
Sent from my MZ505 using Android Tablet Forum
jdsteckling
8
I reloaded the program and tried resetting the APNs and ten deleting the program...still nothing.
Sent from my SCH-I905 using Android Tablet Forum
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
On days when I want to increase my tablets life span, I lower the cpu speed and switch governors for powersave, When I am gaming I increase cpu speed and switch governors for performance.
