Epad 7" Wonder Media WM8650 need help!!!
Discussion in 'WonderMedia WM8650 Tablets' started by gorjos, Apr 5, 2012.
  1. gorjos
    gorjos Member
    Caracas
    Epad 7" Green Led Black port 4gb
    Hi every one! I'm new in the forum. We recently bought 2 Epads 7" Wonder Media WM8650 tablets, and i don't know what models are. They have a green led, black audio port, vibrate, and 4gb memory. I tried to upgrade one of them to a HYBRID_WM8650_UBEROID_1.3.0_v5.7, i followed all the steps, and the tablet got stuck in a " WM8650 Uberoid2.2 upgrade preparing, please wait....." screen. I wait for about 30 min and nothing happend. I tried with almost all the option numbers and have the same result. I don't know what can i do. I't possible to make a rom backup for the other tablet and installing on this one?? I have to wait more time??
    Here is a pic for the details of the original rom:
    Thanks for the help you can give me, i'm desperate already, i just have 5 days with the tablets....
  2. userbe1155
    userbe1155 Senior Member
    plymouth
    wm8650
    Try uberoid v10. This is what I used and it works fine. It sounds like you have same or very similar tab to me, mine was n4gb grn/red led. After trying several changer numbers mine finally worked with no 8. Looking at the details I presumed my tab was a mid703. This may or may not be the same one but its worth a try if you haven't already. Ps did you type in rt3070 before changer no? This helps wi-fi a bit.
  3. userbe1155
    plymouth
    wm8650
    Ps also when rebooting with sd card, leave charger plugged in. Someone somewhere said this makes a difference, don't ask me why, maybe a full power thing, who knows? Good luck
  4. gorjos
    gorjos Member
    Caracas
    Thanks to much for your response!!! I guess mine are mid703 too, but the option 8 does not work either. How much time do i wait to know if its the right option? Where i find the uberoid v10? How can i type in rt3070 before changer??
  5. gorjos
    gorjos Member
    Caracas
    Ok, i tried with the uberoid v10, and install all it!!! It's said "please remove the sd card" and i did it, the tablet shutdown and power on, but only black screen appears, why is that? I'ts been like this for about 15 min, do i have wait more? I choose a bad option??
  6. gorjos
    gorjos Member
    Caracas
    I do the proccess again, and i note an error, appears " *E* Failed to mount Android-Data Partition", is this normal?? After that, it says "Copying files....." and then says: "Please remove SD card". is this normal? How can i repair this error?
wm8650 epad rom
wondemedia 703
