Extending battery?
Ray50
99
I can't quite get a full day out of the battery on my 8024...are there apps you can stop to give you more time? Can you do that without dl app killers so i have control of what is running?
Sent on MID8024/not rooted
Ray50
99
Thanks Spider...good link.
When I check Settings>Applications>Running Services I do see what is running and can stop processes. Right now it says:
Other:43MB in 2
Avail: 65MB+165MB in 13
Not sure what that means BUT it looks like it is easy to stop things if I want to stretch out my battery for an extra hour. I do sync e-mail and exchange calender BUT I could set the auto synch time to 1 hour.
GoldPimp
24
Also something that helped save my battery was turning down the brightness of my screen.
Sent from my MID7024 using Android Tablet Forum
sicvolo
18
I've also found that some video players use software decoding, not HW. This wastes a lot of energy. USB in host mode tends to drain the battery too.
