Fine Volume Control, adds a dial to volume dialog and lets you go below 1 bar volume
Discussion in 'Android Tablet Apps' started by richardop, Aug 18, 2011.
  1. richardop
    richardop Member
    UK
    Hey guys,
    We've rewritten Fine volume control, and it now works much better. It basically allows your volume to be set anywhere from 0-100% (1% being almost inaudible). It's great if the regular 1-volume is too loud on your device, or you want more precise control over audio.
    [​IMG]
    Major rewrite - no longer uses the earpiece speaker
    • With the new app, you get 100 different volume levels from silent to full volume.
    • Control volume with an onscreen dial. Ideal for tablets
    • Works on Media/Alarm/Ringer & Notification/System (in-call excluded)
    • Has an automatic overlay that appears when changing volume (ROM dependent) but also has a regular volume control app
    • Fully customisable
    • For those people using ROMs that don't support the automatic popup, there is a secondary launcher icon that shows the media volume dial for a few seconds.
    Fine volume control V2 (Trial)
    Fine volume control unlocker
    The original app is still available on the market, but now deprecated. If you buy the unlocker app, you can use either version.
  2. alphawave7
    alphawave7 Member
    San Fran
    Nook Color
    Regrettably FC's on my 3.2 A100.
    Sent from my A100 using Tapatalk
  3. richardop
    richardop Member
    UK
    Thanks for the report. I just tested it on a 3.2 emulator and it crashes because 3.2 uses a different volume dialog layout to all previous versions. It's on the todo list :)
  4. alphawave7
    alphawave7 Member
    San Fran
    Nook Color
    Please update this thread when 3.2 version goes gold. :)
  5. richardop
    richardop Member
    UK
    Apologies for the late response!
    The update is out and it should work (it does on my emulator) with 3.2 now but will use 2.X-style volume dialog, not the blue & yellow comet-style native to honeycomb. We can't support that since big G won't release the source.
  6. Brian64
    Brian64 Member
    Adelaide, SA
    Acer A500 Iconia Tab 32gb
    Any chance you could turn this into a widget that sits on a tablet screen? Eg, one that doesn't require hitting the volume buttons first.
    Brian
  7. richardop
    richardop Member
    UK
    A widget is on the way. :)
    • Like Like x 2
  8. Brian64
    Brian64 Member
    Adelaide, SA
    Truly awesome!! Thanks.
  9. FlutteringBy
    FlutteringBy Senior Member
    Samsung Galaxy Tab 4/Galaxy S3
    That's great news!!!......sounds like just what I've been looking for....:D....
    Many Thanks....
  10. richardop
    richardop Member
    UK
    Just released Fine volume control V2, see OP for more details.
    The widget has been replaced with a secondary launcher icon, so you can trigger it from apps like Swipe pad.
