Firmware Based On Allwinner A13 ROMs
Discussion in 'Allwinner A13 Based' started by chiko84, Aug 10, 2015.
  1. chiko84
    chiko84 Member
    Here we leave a list ROMS For based tablet All Winner A13
    (Compilation)
    FIRMWARE-T703-CPUA13-8G-BOARDQ88DV1.1-ESP-NOLOGO-2013-11
    A13-EVB-V1.0-20130926-Android4.2.2-Os-root-MaPan
    T901-3version(A13)(8G)(KB901-v3.4-5(LCD9INCH-CPT-800x480)(GSL3680)(RTL8188)(MC3230)
    A13-Q8-1688-121
    A13 TZX-Q8 713B 800x600 4.0.4
    A13-q75s_j_30606-20130529
    A13-tj-p860-v1.5.4-cob-4.0-20130609
    t733
    t901-3version(a13)(8g)(kb901-v3.4)(lcd9inch-cpt-800x480)(gsl3680)(rtl8188)(mc3230)
    tb_et-86v2g-v1.2-dbl120d_20131212
    q8_pub_doublecamera_virb_4.0.11
    Q88_gsl1680_gc2637660 AL-A13Q8 rev8.0
    A807_A13_silend GSL1680_Gsenser3230AF_Camera_RY5898BDBD2
    T730_sim a13 byeak2531
    t733-mainland-v2.1-2013-09-18
    t730-mainboard-v5.0 st1536-n48
    730-Alphard-A13-touchgsl1680-7-inch-RTL8188
    ET-86V2G-v1.6
    ET-86V2G-V1.5
    t19-0329-hjdz_kf026_dbl_v4.0.4_3klf9k_g_80b_20131
    A13-TW-A0910-V22-1126-gsl3688
    A13-800X480-FT5X_TS-(20130806)-AT75C-ANDROID4.0(4.1)-test-keys.zip
    A13-800x480-ft5x_ts-AIKUN_AT73C_mvta-android4.1-20131220-test-keys.zip
    A13-X1-MGT-Q88DB-V1.2-ZET6251-G605-.rar
    A13-Q8-android4.0-ft5x_ts-20121217-test-keys.rar
    A13-MID08-android4.2-gsl1680-(20130503)_test-keys.zip
    A13_SKYTEX-SP705_7Inch_800x480_Androidv4.1_gslx680_20130531_test-keys.rar
    a13-TJ P860-V7.1-gsl1680-MID-756-V4.2-20130823-test-keys.rar
    tzx-713b v2.1 fix.rar
    A13_TWD_MID-gslX680-800X480_20130423 test-keys.rar
    A13_MID_ft5xt_ts_800x480_ 20120531_v4.0(4G).rar
    A13_ft5x_ts_IMM76D_800X480_Q88_20121217_test-keys.rar
    A13_PMID900_BN05_20130101_v3_OTA.rar
    AL-A13-751-V6.1-metapadc32.rar
    A13-p860-v8.1-V4.0.4-IMM76D-20130302-engtest-keys.rar
    I have more firmware if needed let me know
    • Like Like x 2
  2. ARSO
    ARSO Junior Member
    Hi chiko84;
    im looking for Allwinner A13 KB901 V3.2 2010.10.31 Chinese Tablet Firmware. If listed, which of all the ones it is, if not, where can i find and download it? Thanks in advance.
    Regards;
    ARSO
    ***************************************This is an image of my tablets board***************************************
  3. trebor58
    trebor58 Member
    I have the following tablet that is stuck on startup screen
    Spec:
    Allwinner A13
    CPU: DB061CA-1BJ1
    Board: Q88DB-V1.2
    Can anyone advise how I get this to work again, have tried the on-off vol up-down does not switch on.
    Will any of the above firmware work on my tablet or does anyone have the correct one.
    Thanks in advance
  4. Spider
    Chicago, IL
    Try a factory reset.
    First try turning the tablet completely off for a minute and then turning it back on. (Hold the power button in until you get a shutdown message and select shutdown.)
    Factory reset: How Do I "Factory Reset" My Tablet? | Android Tablet Forum
    If there are no instructions there specifically for your tablet, try some of the methods for other tablets. One of them will probably work and you won't hurt anything by trying.
  5. trebor58
    trebor58 Member
    Thanks Spider for the quick reply, however when I hold down the off button it just switches off no options to select shutdown.
    Out of the list above which would you suggest I try first
  6. Spider
    Chicago, IL
  7. chiko84
    chiko84 Member
    it is more advisable before installing any roms is entering android recobery mode menu and try a hard reset
  8. trebor58
    trebor58 Member
    Thanks chiko84
    As I explained to Spider when I hold down the off button it just switches off no options to select shutdown.
    Do you have rom for this tablet
  9. trebor58
    trebor58 Member
    Up date, Yipeeee I now have a fully functioning A13 tablet, thanks for all your help.
    I just need to find firmware for the other two bricks
    ATM 7013 - ZDB2ADA
    WM 8850 1245 CD
    Any help with these
  10. masayu
    masayu Junior Member
  11. bamor2002
    bamor2002 Senior Member
    algeria
    q7a
    seeking for a firmware to flash qds q7L tablet
    withM
    f727k-mainboard v1.0.0 Topwise-013 2013.03.05
    With digital IC :AXP209
  12. alexluna558
    alexluna558 Junior Member
    Hey bro, i need this firmware a13 7010AA GP 708 512M board WT_GP 707 thanks so much
  13. polarot
    polarot Junior Member
    Please help me out with this A13 ROM CC029CA 1CF1
  14. Wajidalikhan
    Wajidalikhan Junior Member
    I need Firmware for this (1 or 2 Anyone)...please help....
    1).A13-P860-V8.1 nuclear_evb-eng 4.0.4 IMM76D 20130608 test-keys
    Or....for this one
    2).A13-P860-V8. 1 nuclear_evb-eng 4.0.4 IMM76D 20130822 test-keys
  15. stringskip
    stringskip Junior Member
    my tab is stock in android logo.. i've flushed a few ROM but the touch features are not working.. hope somebody could help me find a compatible ROM for my tab..
    here are some infos fo my tab:
    description: nuclear_evb_rt18723au-eng 4.0.4 IMM76D 20131225 test-keys
    displayID: 86VE1-B1-H1-H01-DS40.1312103.20140326
    buildID: IMM76D
    product: nuclear_evb_rt18723au
    hardware: sun5i
    revision: a13b
all winner tablet
allwinner a13
allwinner a13 firmware
allwinner a13 firmware download
allwinner a13 rom
allwinner a13 tw a0910 v22 1126
china tablet a13 firmware download
tw-a0910-v22-1126
tw-a0910-v22-1126 firmware
tw-a0910-v22-1126 firmware download
