Firmware for SAWEE WWE 101-MAIN V3.4
Discussion in 'SuperPAD II Firmware' started by spy_station, Apr 23, 2012.
  1. spy_station
    spy_station Member
    Hello Everyone!
    I need help with my Android Tablet!
    It's a SuperPAd III. I had open It and in the mainboard says: WWE 101-MAIN V3.4 .
    Could you help me?
    Thank you
    Allan
  2. leeb
    leeb Member
  3. spy_station
    spy_station Member
    Hi! Thanks for answering!
    I tried to use this firmware! Now, the tablet "works", but the WIFI/CAM/SOUND aren't working.
    Could you help me?
    Thank you again!
    Allan
  4. spy_station
    spy_station Member
    Do you know if is It possible to copy the firmware from another tablet?
    Thank you!
  5. leeb
    leeb Member
    Have you been able to root it in its current condition?
    What did the initial boot screen show?
    Did it show TUX in the upper left after that?
    Did it have the 'glittering ANDROID' after the 'typed' one (as the gen1 version does)?
    There are others that might work better, but this is the one that worked best on mine (with defective flash)...
    AFAIK the 'sound' is built-in to the SOC...
    Perhaps you should disconnect the battery for a short while and then try it again... that might help! :D
  6. sabrish
    sabrish Member
    Erode
    Android Mid Tablet w8560
    Hi im new to this forum...
    I have a Android Mid Tablet!!!....
    i bought this before a week....but today when i switched it on...some grains are appearing in the screen...ther is no other operations than is...what will be the problem??
    Can anybody help me to fix this & get out of this problem???
  7. spy_station
    spy_station Member
    Yes!
    Yes!
    I will try It.
    Thank you
  8. Billy_Lunch_Money
    Billy_Lunch_Money Member
    leicester
    Flytouch 2/Superpad III ?
    I have the same board, I might be able copy the firmware for you. If you still need it.
wwe101-main
infotmic wwe 10 firmware
sawee pad
tablet wwe101
tablet wwe101 2010
tableta sawee pad
we101 main
wwe 2012 tablet 2
wwe101
wwe101-main
