Firmware Problem ZT-180 II to the Latest Firmware : 10.2 Inch 512MB RAM +
alanh
Good Day I have loaded firmware from http://blog.wholesaleonepiece.com/update-zenithink-2-zt-180-ii-latest-firmware-10-2-inch-512mb-ram-4gb-tablet/
and the firmware installed but I was unable to select one of 4 options to complete the installation. One of the options was "Setup Wizard" and another was "Use by default for this action" any suggestions would be most appreciated? Thanks Alan (my original problem was that the epad locked and I could not use the device)
TVLmole
Hi alanh
The upgrade you have indicated is 0311 and has been replaced with ZT180_G2_J2.4_102_Android2.2_1126_8388. There are two versions depending on which sound card you have, either the ESS8388 or ESS8898. I have flashed my Epad and it works fine. I am not aware any any other effective upgrades for this tablet to date.
Regards
TVLmole
