probably it will be ok, Just try to flash the right firmware. with 4GB internal memory you probably need 'HY' firmware. with 2GB normal m701 firmware. If you have hardware volume buttons it might be that you have a 's22' and no m701
i like my old #181 from 16.11 best for my 2GB M701 + clockworkmod + battery.ko fix + mali.ko fix + build.prop mods + i dont remember... i changed a lot over time
hey i got some questions sorry cuz i ask alot 1- when i try to move apps to sd it says make a 2nd partition 2- why there is no swype keyboard like my android phone? 3- does it support mozila firefox? 4- does it support 3g usb modem?
Hmm, lets see. 1- i dont know, isnt app2sd a android 2.2 option? 2- just install it from the market? 3- There is no Android version of firefox. Try Dolphin Browser. 4- it should support at least some, this is the last list i could find: HUAWEI EC122 ZTE AC2766 ZTE AC580 SINCOM SE 189-U Gemtek W3GUBV-100 HUAWEI E180 HUAWEI E1750
