firmware upgrade
mink29
i have just tried flashing elf using the prescibed method but when i get to the pluging in while holding menu then pressing start repeatedly all that happens is livesuit dissapeares but no other boxes appear for me to carry on with install if anyone can tell me if they have had same problem or if im pressing wrong buttons i would be gratefull (im pressing button with 3lines on it not the home button) seems very convoluted method to upgrade but who am i to comment :)
KillerKink
Developer
Mar 16, 2011
361
77
Were you able to start livesuit before connecting the tablet? You should be prompt to install drivers if you are do livesuit update for the first time.
mink29
as i am new to this i dont really know what you mean. the actual program started up when i clicked livesuit exe just went into the usual start up as far as i know:confused: ( livesuit wizard )
KillerKink
Developer
Mar 16, 2011
361
77
when you start the livesuit, you should pick the firmware. When you get into flash mode(menu and power button), you should be prompt to install usb driver if this is your first time.
