Fix for stuck on TUZ
Discussion in 'Augen Gentouch' started by greeen, Dec 29, 2011.
  1. greeen
    greeen Member
    i think i found this on this forum some were. no special **** required to install. i had my gentouch for about 2 weeks and finally stuck on tuz screen out of the blue. all you need is the usb cable.
    posting the fix soon
  2. greeen
    greeen Member
    im sorry it was on another website
    this is from a member named stu on another forum
    ""Posted 24 July 2011 - 01:34 PM
    Mine is doing the same thing (again.)
    This is the original issue I sent it in for late last year. As an FYI, Augen was actually able to fix it so there is a solution I just have no idea of what it is.
    I have some of the updates saved for the thing:
    http://seantu.com/Au...ware_100809.zip
    http://seantu.com/Au...ware_100917.zip
    i hope this helps it did for me.
    the 100917 worked for mine.
    follow the pdf and it will work
  3. greeen
    greeen Member
    well at least it got it up and running. im very new to android. i jailbroke my 1st gen itouch so this cant be much harder.
    is there an underground market? theres a lot of aps i would like to put on this tablet.
    how does this thing know my location? out of all the devices i use this one is the only one that tarced me back to my home town.
    ive downloaded a few aps like gas buddy and IMBD but both worked poorly with this devices. when i tried to scroll it would just click on something after the scroll was finished.
    im going to attempt to do the rooting etc here in a few. any sugestions?
    i think this tablet is about dead on any forum. most links are dead and none to be found.
a tu z androi gemes
