flashed wrong firmware v811 v8 to a v811 v1
Discussion in 'Onda Tablet Forum' started by huunreh, May 1, 2013.
  1. huunreh
    huunreh Member
    hi i flashed a v811 v8 firmware to my onda v811 v1 tablet. and now i cant enter recovery menu by pressing home+power button and it cant be reflashed with amologic flash program(USB-Burning-tool) either. the only way that i could enter recovery menu was Adb reboot recovery by using these methodd (How to Enter Recovery Mode on Any Android Phone or Tablet - Tutorial / Guide -> Method 2- How to Enter Recovery Mode on Any Android Phone or Tablet - Tutorial / Guide ) and this (How To Set Up Android ADB & Fastboot On Windows [Tutorial] | Redmond Pie - How To Set Up Android ADB & Fastboot On Windows [Tutorial] | Redmond Pie ). when i enter recovery using that method and try the menu (Apply Update from TFcard) and select update.zip after verifying the file it gives this error: assert failed: !less_than_int(1353131331, getprop("ro.build.date.utc")) installation aborted. i have tried with all the firmwares that worked fine and now i cant do anything. although my tablet works but its wifi dont work and its ram is now less tahn 300 mb(before it was about 600 mb). any help would be appriciated, thank you guys!
  2. umar_fiaz
    umar_fiaz Member
    knc 705, novo 7, Onda
    Hi,
    i also faced this problem, when v7 was out & my tab was useless...
    NO wifi, No proximate sensor... :(
    i tried many methods but can't recover from that.. Same thing again happens when v8 was out... but now i know the way to recover from it... the all problem is because of flashing wrong "Kernel"
    ADB or recovery wont help...
    even the V811 not detecting in "M3 devices" or "world cup device mode"
    "The Device is HARD Bricked"
    I searched every where but there is no solution for fix.... then i tried hardware trick to recover from Hard Brick
    100% working
    first thing to do is disassemble your tab.. here ho to do this
    *you don't have to disassemble the LCD or touch Panel
    Just open up the tab
    then you have to locate flash memory chip
    At this point you should have the device plugged in and the AML software open. Have the Windows Device Manager open in another visible window and you should also be able to see if there is a Device change in the AML command prompt looking screen.
    On the left side of the chip there are a series of pins.
    Using metal object, bridge those two pins by creating a connection between them.
    press and hold the Power and home buttons
    The device may show up in the Device Manager as an M3/M6 chip at this point and as connected to a port in the AML software. You can remove the metal object and Flash the device with compatible firmware.
    if not work, cut the battery red wire and do the above steps
    when flash complete disconnect the TABLET and reconnect the red wire.
    Enjoy your TABLET fully working..
    Happy Unbricking
    This method could be applied on ONDA v801 dualcore as well because both have same main board instead of LCD
    • Like Like x 2
  3. huunreh
    huunreh Member
    thnak you for your reply my friend. i will try that and will post the result.
  4. huunreh
    huunreh Member
    how to open back cover? i opend 4 screws and now it seems impossible to open back cover?
    SOLVED: using this video(www.youtube.com/watch?v=5HByRiW_cPs)
    () and a credit card!
  5. huunreh
    huunreh Member
    i couldnt understand your way, should i connect A Pins to B Pins? or should i connect A pins with each other and B Pins with each other without connecting A and B?and how did you connect those pins?
    with screwdriver? with what piece of metal?
  6. umar_fiaz
    umar_fiaz Member
    This one
    Regards :)
    • Like Like x 2
  7. loki1
    loki1 Member
    hi,
    I also have the same problem http://www.androidtablets.net/forum...133-onda-v801-recovery-mode-doesn-t-work.html
    I tried this weekend, but it does work for me, i stay blocked on white android and no "world cup device mode" or "M3 devices" :confused:
    • Like Like x 2
  8. vinhnt88
    vinhnt88 Member
    • Like Like x 2
  9. huunreh
    huunreh Member
    thanks for your reply, i tried the pins you noted but still no luck, could you explain more how you did it?
    thanks
  10. huunreh
    huunreh Member
    thanks for links, they gave much more information on what we want to do. it appears that we need to locate "TF-Boot" pins on the HYNIX H27UCG8T2MYA AND somehow connect those pin with each other.
    any suggestion that can point us in the right direction would be welcomed.
  11. umar_fiaz
    umar_fiaz Member
    i just point the space which you have to short, I have tried it with a small screw driver, i found the last pins working to get device in "WORLD CUP Mode" flash mode. and also you should have to start "AMLogic Flashing Software".
    • Like Like x 2
  12. emrangrf
    emrangrf Member
    Onda V811
    Dear umar_fiaz, could you please specify what was the model of your NAND Flash?
    mine is 29F64G08CBABA and i can't fins the desired pins to shorten...
  13. krizis
    krizis Member
    Are you talking about h27ucg8t2myr and which side bottoms pins work ?
  14. umar_fiaz
    umar_fiaz Member
    for me it was "flash1" chip left side last pins on up side battery
  15. tungbt299
    tungbt299 Member
    Hi you,
    Did you solved the problem of your Onda V811? Show me the solution, pls! I flashed firmware v3.12 for V811 V8 to my V811 V1 and now doesn't work and I can't do anything. :(
29f64g
dixon tablet hard reset
dixon tablet v8
dixon tablet v8 hard reset
dixon v8 tablet hard reset
drivers for dixon v8 tablet
how to hard reset dixon v8 tablet
how to unlock a dixon v8 tab
how to unlock dixon v8 tablet without pattern
recovery screen on dixon v8 tablet
