Flytouch 2 wowpad not fully charge 100%
rebin
HI every 1
it would be great if some one help me
i have Flytouch x220 i have left it on charge for 6-8 hrs when i remove the charger from the power, and still not helf charge and i can not login to the market using my gmail usr and pass..
thank you
rebin
Mar 22, 2011
Hello Rebin,
I have the same problem (can not login to the market using my gmail usr and pass..) I had to factory reset the pad and it worked after that.
Regards the power problem, mine will charge to 71% them jump to 98%. It will never charge to 100% and when i remove the charger, the battery indicator drops to 71%
Regards
David
