Flytouch V10 Superpad will not connect to wifi at home or hotspots
Discussion in 'Android Tablet Q&A' started by JeanUK2012, Dec 22, 2012.
  1. JeanUK2012
    JeanUK2012 Member
    England
    Flytouch Superpad V10
    The wifi used to work but has gradually deteriorated. It started to take longer to connect now it is connecting then obtaining IP address, then authenticating and then just disconnecting. The tablet states network is 'disabled, secured with WPA/WPA2 PSK'. This also happens in free wifi hotspots. It will just no longer connect. Any suggestions. Bought this on Ebay, no joy from the seller. Can I send it back to Gome as it is under 1 year. It is not the router (3Mifi) as my mobile phone works on it. :confused:
  2. Rowdyeh
    Rowdyeh Member
    Australia
    Google Nexus 7
    Hi Jean. Not sure warranty is transferable but you might be lucky. Check your documentation. Free WIFI spots typically do not have any encryption and should not be used for sensitive transactions. Perhaps a firmware upgrade may solve your problem but if it's a gradual deterioration, that points to hardware issues. If you can, by all means send the tablet back for repair under warranty. However due to possible costs it might be better to purchase a better and newer tablet. Good luck and Season's Greetings!
  3. Spider
    Chicago, IL
    Hi Jean, welcome to the forum. Sorry to hear you're having problems with that tablet of yours. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
android tablet no longer connecting to any wifi
