Just purchased Flytouch2 from this seller 10.2" FlyTouch2 Android 2.1 WiFi GPS Camera Tablet PC - eBay (item 280578657015 end time Nov-21-10 00:19:54 PST) Everything works fine apart one problem, on right screen side I see button "register" that asks me to enter license number. Then in About device page in bottom I get this: Certification Certification of this device is not passed, when I click on it I get same poppup asking to enter license number. What is it anyway?
Hello, i have the same problem and I search for internet and I don´t found nothing. How I can resolve the problem? Thank you
Hi purchased one, you should have recieved a license number to enter to completly open the Tablet. I would go back to the seller and ask them to provide you one. Hope this helps
Thank you for your comments. I don´t have posibility to contact with seller. Other friend comment to me that it is posible that register if for any program. I look for it. Thanks
There are two versions of this product. 1. One version has (a) internal GPS and (b) comes with a registration number. 2. The other version (a) supports only external GPS and (b) does not come with a registration number, and furthermore (c) will frequently remind you that it is not registered In the link that you gave, the seller says it has internal GPS and comes with a registration number. So if you bought from that seller, it should have come with a registration number.
