Found a cheap USB charging solution, YMMV
Discussion in 'Huawei Ideos S7 Accessories' started by Joshua, Nov 28, 2010.
Thread Status:
Not open for further replies.
  1. Joshua
    Joshua Member
    Lousiana
    Too Many
    Found a retracting USB to Pin/Barrel connector at Dollar Tree that fits and charges the S7. Keep in mind it may take 6-8 hours to charge over USB. Hope this helps you guys out.
  2. Carbira1
    Carbira1 Member
    Michigan
    Waiting for a good iPod Touch Android Device
    That's cool. What's the quality of the cord?
  3. Joshua
    Joshua Member
    Lousiana
    Too Many
    Very thin, but it is one of those retracting style cables and its only a buck, so you can buy several incase they break.
  4. WXMAN
    WXMAN Member
    NULL
    Is there any concern about getting incorrect voltage with this method?
  5. pa49
    pa49 Senior Member
    UK
    Huawei S7, Nokia X3-02, Nokia E71
    No need to worry about voltage!
    All USB "ports" should give a nominal 5v.
    Just make sure the cable is fully unwound a check on heat build up from the current shortly after plugging in.
    I'm going to see if I can track one of these down today and give it a test as well as the Duracell "combo" charger mention in other posts.
Thread Status:
