Froyo Audio Equalizer on QSD8250 vmsplit2G
Discussion in 'Huawei Ideos S7 Development' started by xaueious, Apr 25, 2011.
  1. xaueious
    Canada
  2. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    Will something like this help get our 2.2 s7's back to how our volume and mic used to work in 2.1?
    Sent from my IDEOS S7
  3. Limey
    Limey Member
    S7
    Yes it should, from what I've read you can increase the dB level. There is or was a disclaimer stating you can damage the speakers. There are settings for bluetooth, headphones and speakers.
  4. Limey
    Limey Member
    S7
    OK installed and working without a problem.
    Bluetooth seems clearer.
    Speakers are louder, I'm not sure its a big increase but its there.
    Headphones are like WOW!!! Bass is deep, highs are nice. Big difference. I have the volume at about 50% anymore and its to loud and starts to distort at about 80-90%
  5. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    Did you just install the apk........ Or did you extract the whole zip to a directory then run the apk?
    thx
  6. dgnyberg
    dgnyberg Member
    Sterling, Illinois
    Huawei S7
    OK, I would like to increase the phone volume also.
    I am quite new, and want to make sure I install it right.
    I downloaded it, and there are multiple directories in the zip file.
    What do I need to do to install it?
    Thanks in advance!
    Peace,
    Dave
  7. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    ok , so i unzipped and got a DSPManager folder...... then i just copied the whole folder to my Internal SDcard.
    Open root explorer and navigate to your SDcard > DSPManager folder > System > App
    and click the APK and install it.
    Installed fine, can see the 3 settings for Headset / Phone Speaker / Bluetooth
    havn't enabled anything yet so will mess with it later
    I have also downloaded AudioBooster 2.4 , it has an option for your Mic to boost it , will mess with that later too...... I tried AB 2.0 but when i hit mic enable then exit and come back it was disabled. There is an option to QUIT and leave it running in backgroud as a service, but i still didnt notice any louder mic recording. Maybe 2.4 will be better...
    • Like Like x 2
  8. dgnyberg
    dgnyberg Member
    Sterling, Illinois
    Huawei S7
    Works GREAT!!
    Thanks for the instructions!
    Peace,
    Dave
  9. hoopa
    hoopa Member
    idaho
    xoom
    Ppplinyhvyrbf:) fyGvbudbedrbfybygbtftfbgGrbfythgkvojtbygitgntyghnfuvnf
    Sent from my Xoom using Android Tablet Forum
  10. dgnyberg
    dgnyberg Member
    Sterling, Illinois
    Huawei S7
    Huh????????????
  11. ramcharger1979
    ramcharger1979 Member
    Boise, ID
    Huawei S7
    I installed this via recovery and I notice the difference instantly. Clear sound and a more true stereo sound.
  12. Limey
    Limey Member
    S7
    I installed it using recovery, easiest way. Love the sound that comes out of the headphones now.
  13. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    @Dammit...... just verified those three files installed to system /lib
    might mess with it some more.
    Did install audioboost 2. 4 and can enable mic and speakers setting. After reboot buttons are still enabled.......... Versio 2. 0 or 2. 2 wasn't retaining settings.
    Still don't notice big improvement as far as mic recordings being louder.
aplikasi equalizer froyo
aplikasi musik equalizer untuk froyo
audio equalizer for froyo
bass eq apk froyo
download equalizer audio untuk proyo
dsp manager apk froyo
eqializer for froyo
equalizer android froyo
equalizer android froyo apk
equalizer for froyo
equalizer for froyo apk
equalizer for pandigital tablet
equalizer froyo
equalizer froyo apk
equalizer huawei apk
huawei equalizer
music equalizer for ideos
music equalizer froyo
volume audio froyo
