G-sensor fix
Discussion in 'Huawei Ideos S7' started by MarCreative, Dec 25, 2010.
  1. MarCreative
    MarCreative Member
    Hi Folks!
    I've a new S7, and am verry happy with it. But there's an problem: my g-sensor. It is reverted.
    So, I looked on Google like I alway's do and found an solution:
    1. Run ConnectBot
    2. Connect: choose local (enter)
    3. Type: setenv gsensor_axis 0,-1,1,1,2,1
    4. Type: exit
    5. Reboot PAD
    I did exactly the same steps, except I logged in as root. But, my device says: setenv not found. What must I do to fix this problem, there is something about bash but don't know what!
    Thank you in advance
  2. fosormic
    fosormic Member
    Im not sure whats going on, but busybox adds a few things, try to install it.
    Sent from my Ideos S7 using Android Tablet Forum App
  3. PaperPro
    PaperPro Member
    No BusyBox (Professional) Does Nothing to Help the Issue. Does anyone know how to solve this?
  4. cansat
    cansat Member
    EspaƱa
    Huawei S7 - 105
    g-sensor-fix
android g sensor problems
fix g sensor android
g sensor busybox
g sensor fix
how to fix android g sensor
how to fix g sensor on android
how to fix g sensor problem
how to repair g sensor
nextbook tablet 7 g sensor
repair g sensor
