I rooted the coby 7015. Everything works fine but when I play a game which use the G sensor it doesnt work fine. Kind of slow. Can I calibrate or do something?
Thanks!
The G Sensor works fine with books, wallpaper, applications. It only happens in Raging Thunder and 3D games. It works but inverse. I see the game in horizontal and I make my moves in vertical. I read in another forum that the problem is with android market 3d games. If you download the games since appslib it works fine. It sounds kind of strange but I´m gonna try and then I will tell you what happens.
