Good retail MicroSD card for rooting?
Discussion in 'Nook' started by jwhite, Jan 10, 2011.
  1. jwhite
    jwhite Member
    Orange County, CA
    nookColor
    Rooting instructions suggest using a class 6 microSD card for rooting. Is there a good retail source? Frys.com doesn't list the class. Bestbuy.com doesn't list the class (well, the only one listed is class 2).
    Any suggestions?
  2. illdill
    illdill Member
    Charleston
    rooted NC
    Frys.com actually does list Class on some, here is a 16 GB Class 10, was 27.99 when I bought went up to 32, FRYS.com | 16GB MICRO SD C10
    Class 10 is the best.
    Target also carries a Class 6 8 GB with a USB microSD adapter for over 30 dollars.
  3. thel8elvis
    thel8elvis Member
    VA
    nook color, huawei IDEOS, Pandigital Novel
    I'm not sure I understand why they would recommend that. I used random class 4 card I sitting around... The class refers to write speed ... and is generally more important when using for things like writing video information in a camera/camcorder ... not for an ebook reader to read from ??
    That being said ... amazon, newegg both can be searched for cards based on class rating.
  4. gadgetrants
    gadgetrants Moderator Staff Member
    Asus OG Transformer, Droid 3
    +1 What ^ he said. Class 2 is fine. Don't by the hype on faster cards, not necessary for an eReader.
    -Matt
  5. J515OP
    Northern CA
  6. gadgetrants
    That's a good point. Wish I'd thought of that. Scratch what I said above. Speed matters. And size. ;)
    -Matt
  7. jwhite
    jwhite Member
    Orange County, CA
    nookColor
    I really did mean retail, not mail-order as I was looking to do it ... maybe tonight, but thanks for the Amazon link anyway. That's not a bad deal. My thinking was that I'd get an inexpensive lower capacity card for rooting. If I need something for some other purpose, I'll get one for that purpose.
    All the retail 2GB cards are around $10, which doesn't hurt the pocketbook. I'll try one and report back.
  8. jwhite
    jwhite Member
    Orange County, CA
    nookColor
    $10 PNY 2GB card worked fine.
    I bought and used the:
    P-SDU2GB-EF/BG
  9. rico2001
    rico2001 Senior Member
    Charlotte, NC
    NOOKcolor
    All are good, although I'd stay with class 2 to 6. Some people have had issues with the higher classes in their mobile devices.
    @OP
    I'd get any 1-2 GB microSD card for rooting purposes.
  10. IAC
    IAC Member
    Montreal, QC, Canada
    NookColor
    Dell had a deal on a Kingston Class 4 4GB for $7 a couple days back... not sure if it's still on (here in Canada). I bought one, just as a backup. My main is a class 4 16GB... also Kingston.
  11. jwhite
    jwhite Member
    Orange County, CA
    nookColor
    Thanks. This is the one I used from Best Buy.
  12. rico2001
    Charlotte, NC
    NOOKcolor
    Good choice, I like pny memory.
