GPS not accurate, it shows i m in another country,how to adjust it.
Discussion in 'SuperPAD II Firmware' started by dhj123456, Nov 7, 2011.
  1. dhj123456
    dhj123456 Member
    South Carolina
    Superpad 2
    Sent from my DISCO10 using Android Tablet Forum
  2. Tom T
    Tom T Senior Member
    Washington State
    Hauwei S7
    Are you positive you are right and it is wrong? It actually happened to me once.
  3. bonzobritt100
    bonzobritt100 Member
    superpad III
    I am in the same boat, it keeps telling me I am in China, and of course, I've done the whole GPS test routine, put the external antenae on, gone outside, held the "battery side" to the sky, etc. No luck. So if you have a suggestion, please let me know, becasue I am definitely not in China, and am in Anchorage, Alaska. I need the GPS to work so I can get my maps working. HELP.
  4. greenfrog
    greenfrog Member
    NULL
    If you have GPS Status installed, have it reset the GPS data and then set the tablet outside for at least a half hour and see if it can find your location. It may take a long time to find your location in Alaska.
why does my gps show me im in another country
