Graphic problems
luck008
21
Hello, i'm having some texture problems in games like gangstar and need for speed shift.My question is:If i change the vm heap to 32 or 48 mb the problems might be solved? ty(coby 7015)
popeye1128
186
16
Why not just try it and see? Use VMHeap Tool. Kinda doubt it will fix texture issues though, the GPU probably can't handle the graphics.
driggs
81
Are you running the base ROM or one of the customs? I agree with Popeye that it is probably a hardware limitation with the GPU, but if you are still looking for things to try, you may want to try the graphics fix for Angry Birds (if you haven't installed it already).
Apr 28, 2011
201
13
The graphics fix for angry birds (sticky in the technical forum) works great. Your tablet has to be rooted and clockworkmod installed for it to work, but it does work. I rooted mine yesterday, it was successful and i enjoy having it rooted and the fix.
