hello and lookning for help please
Discussion in 'APAD IMX515' started by ughlee29, May 19, 2011.
  1. ughlee29
    ughlee29 Member
    just looking for some input or help with a problem i have come across....got a apad imx 515 and cant seem to get any 3d games to run (i.e. gameloft games...) anyhow i download opengl info and found my tablet has a z430 chip in it which should be able to run those games...so i tried the electopia benchmarch and was told i have no hardware support for opengl 2.0 so it wouldnt run...
    according to the manufacturer this chip should do that...is the pad defective (it does work fine other then that) or am i just outta luck? any ideas or help would be appreciated.
    its the 2 screw 1 speaker version and ive tried the original and xaumods firmware both with the same effect..
    also when i update i get 2 errors (uboot and kernel errors)
    would this effect it and how would i go about fixing that?
    sorry for the wall but any help would be appreciated
  2. nakamuramiku
    nakamuramiku Member
    日本 シンガポ&
    heroTAB M802 With Camera, Apad RK2808, Motorola DEXT MB200,
    Hmmmm! Is you tablet Utopia Apad IMX515? There may be many variants out there which makes the ROMS incompatible. I had the same problem too. 3D games would not even load & makes my tab restarted OS. I had the reinstall the firmware using Xaumods. I press Update ALL & the Wipe all Factory Reset. 3D games works fine.
