hello - Need S7 Slim Lockcode Help
Discussion in 'Huawei Ideos S7 Slim Technical' started by elizabethraul, Sep 23, 2011.
  1. elizabethraul
    elizabethraul Member
    Bahrain
    huawei ideos S7 slim
    hello my name is elizabeth! i need your help guys!i forgot the screen unlock code for my ideos s7 slim tablet, what can i do to open and reset the settings?
  2. idontknow
    idontknow Alternate ATF App Tester
    miami,fl
    galaxy note,galaxy 8.9 ,nook color
    A friend who had a similar problem got help from the store where she bought it, she had to prove that the tablet was hers though.
    gg
  3. Spider
    Chicago, IL
    Hello Elizabeth, welcome to the forum. Nice of you to join us. I'm moving your question to the Huawei Ideos S7 Slim Technical section of the forum where someone should be able to help you.
  4. audiovideofile
    audiovideofile Member
    Philippines
    S7-SLIM
    Hi Elizabethraul did you solve your problem with ideos S7 SLIM, i am having the same problem with my ideos can you help me out if you were able to solve your problems with same tablet as mine, thanks and i would appreciate it much!!!
code pasword tab ideos s7 slim
how to unblock huawei s7 slim
how to unlock huawei ideos s7 slim tablet
how to unlock ideos s7 slim
how to unlock pin on ideos s7 slim
kode sos ideos s7 slim
qual o pin do ideos s7 slim
reset phonelock on huawei ideos s7
tablet huawei s7 slim 201u forgot password
unlock huawie slim s7 without password
