HELP... Coby Kyros dosn't turn on
Discussion in 'Coby Generation 2 Technical' started by mgonzalez87, Oct 14, 2011.
  1. mgonzalez87
    mgonzalez87 Member
    Edinburg TX
    coby kyros MID 7022
    Hey,
    I'm new to this, so the other day i was messing around with FWDN_V7 and the kl.rom. now my Tablet doesn't turn on...(MID7022) ​
  2. Pickupman66
    Pickupman66 Member
    Tennessee
    Samsung Captivate (Rooted) Coby Kyros 1024
    is it fully charged? does it show any charging at all? any boot up screens?
  3. mgonzalez87
    mgonzalez87 Member
    Edinburg TX
    coby kyros MID 7022
    yes its fully charged the green light is on...no boot up screen... and the computer dosn't detect it
  4. trickbiker121
    trickbiker121 Senior Member
    Coby Kyros MID7022
    sounds like a full brick. You don't even see the Coby logo?
  5. piratesscareme
    piratesscareme Senior Member
    Try pushing the reset button on the back for a couple of seconds and then turning it on.
    Sent from my Kyros MID7022 8K using Tapatalk
  6. mgonzalez87
    mgonzalez87 Member
    Edinburg TX
    coby kyros MID 7022
    No... logo comes out....
  7. mgonzalez87
    mgonzalez87 Member
    Edinburg TX
    coby kyros MID 7022
    i tryed everything....
  8. Pickupman66
    Pickupman66 Member
    Tennessee
    if you are seeing the Logo, that is a good sign. have you tried to put it into recovery mode?
    Download the stock firmware
    1. Copy all files to a MicroSD card, i recommend a clean one...
    2. Recharge
    3. After recharge TURN OFF ( you are already off.
    4. Insert the card at the MicroSD slot
    5. Press the home menu, keep pressing and TURN the tablet ON. Release both keys when the screen lights up.
    6. After that, a recovery menu will appear, then you can release the home button.
    7. Wait a few minutes while system works
    8. System will shut down, TURN it ON again
    9. DONE!
  9. mgonzalez87
    mgonzalez87 Member
    Edinburg TX
    coby kyros MID 7022
    it dosn't trun on at all
  10. trickbiker121
    Coby Kyros MID7022
    Sorry the only thing you can do is exchange it, return it or call Coby and get a RMA. Sorry
  11. viseversa101
    viseversa101 Member
    coby kryos mid1024
    I have the same problem, however i do have the logo yet thats all i see...these steps didnt help, any other suggestions?
  12. lfom
    lfom Senior Member Developer
    Brasil
    What's your tablet model?
    What firmware did you use?
    If the process ended without errors on screen and it's stuck in the Coby logo then maybe your internal microSD is bad.
  13. viseversa101
    viseversa101 Member
    coby kryos mid1024
    i have a coby kryos mid1024
    firmware was the latest 1024 available thru coby
  14. lfom
    Brasil
    You may wanna try a firmware I made for MID1024 and will be released soon. It shows more info on screen so you know what's going on. A pre-release version is available here:
    http://www.androidtablets.net/forum...dix-touch-drivers-gingerbread.html#post139523
    If the update goes until end with no errors and you still get stuck in Coby's logo then probably you have a defective unit, either microSD or something else. If it's warranty I would request an exchange. The first MID1024 I got would reset and lose all my settings, then it was replaced and the new one is fine so far.
  15. viseversa101
    viseversa101 Member
    coby kryos mid1024
    Omw out for dinner, il give it a shot when i return and provide feedback. This unit was bought early Aug beginning, of fall semester so its less than 3 months old.
coby kyros mid7048 wont charge
coby kyros mid7048 wont turn on
coby kyros not turning on
coby kyros tablet power button broken
how to know if coby kyros is loading
how to turn off coby tablet
how to turn on mid7048
light comes on but do not work kyros tablet
my kyros wont turn off
why doent my coby turn on
