HELP... Coby Kyros dosn't turn on
Discussion in 'Coby Generation 2 Technical' started by mgonzalez87, Oct 14, 2011.
  1. viseversa101
    viseversa101 Member
    coby kryos mid1024
    ok so this was never rooted, basically stock so i would imagine the problem i am having with this suggestion is me not having a rom emulator? is that the case? if so ne suggestions on which to use and it goes on the external sd correct?
  2. lfom
    lfom Senior Member Developer
    Brasil
    Hmmm, no. You can try installing another firmware, if it doesn't help, then probably you have a defective unit.
  3. Pickupman66
    Pickupman66 Member
    Tennessee
    Samsung Captivate (Rooted) Coby Kyros 1024
    Don't think u need a rom emulator. Just download the new rom (the one linked earlier word awesomely). Extract the files and then drop the contents (should be several folders and files) onto a freshly formatted microsd card. Format it fat 32. Then put that in the unit. Turn off and hold home button then push power and hold till screen lights. Let go and it will work. Will update the statuses on the screen.
    Pecked out on my rooted Kyros MID1024
  4. viseversa101
    viseversa101 Member
    coby kryos mid1024
    i am gonna vote this is defective, it partitions and instead of writing to it it reads mmc init card successfully, mode end, mode 2 end, n shutdown....thats it n even if i just boot the thing it gives me the error that coby firmware is supposed to be debugging in the update, which i never experienced befor the update...grrr
  5. jdagraf
    jdagraf Member
    Hi, yesterday I was reading about my old Kyros 1024, I found the Volcano Mod and I installed It, it worked fine, but I turned off the kyros and when I tried to use it again it doesn't get pass the kyros logo. Is fully charge, what could it be? Everything worked fine at first.
coby kyros mid7048 wont charge
coby kyros mid7048 wont turn on
coby kyros not turning on
coby kyros tablet power button broken
how to know if coby kyros is loading
how to turn off coby tablet
how to turn on mid7048
light comes on but do not work kyros tablet
my kyros wont turn off
why doent my coby turn on
